Old 09-30-2008, 10:02 PM   #11 (permalink)
Sideblinder
I know that old radial aircraft engines used to use a power recovery exhaust turbine. It was a turbine, powered by the exhaust gasses, but the shaft actually went through reduction gearing to the crank shaft. If I remember correctly they were supposed to increase power to weight by 8%. I'll dig out my books and find it. I know nothing like this is used in modern aircraft, only regular turbochargers.
