Old 10-01-2008, 01:51 PM   #5 (permalink)
wagonman76
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Originally Posted by ac7ss View Post
dont forget thermal expansion in the summer. Dremd is right abuot your emissions system if you are filling up to the throat. if you are just filling to the base of the fill tube, you should be ok.
Thats the main reason I dont do that, I would worry about losing gas due to expansion. Not only summer, but I would think that the expansion from -20F to 20F would be the same as 50F to 90F.
To try to minimize the difference between pump shutoffs, I count seconds to myself and pump at about .1 gallon per second. And I go to the 2nd clickoff. The only time I get a bad fill is when the pump is broken and the shutoff doesnt work and it overfills. Also, before even getting out of the car, I make an educated guess of what itll take to fill the tank to start with, so if it kicks off way too soon or not at all, I know somethings up. Also if the car is on a slope, itll affect the fill a bit depending on where your fill tube enters the tank.
Winter daily driver, parked most days right now
Summer daily driver
