Originally Posted by mopo3
Why not cover the exhaust pipe(s) with peltier heat pumps to generate electricity.
I have fantasized about this for quite some time. Then I ran the numbers on it: pricey. Still, it'd eliminate a parasitic drag on the engine, and could conceivably generate enough current to run even a hybrid's recharging cycle - hell, stick the Peltiers on the engine block, radiator, everything. Anything that gets warm, make that heat do something useful.
You're not in front of me...
I'm 25,000 miles in front of you.
