FWIW, I have seen people cite used oil analysis done on the same engine run with a K&N filter and a disposable paper filter, and the oil that was run when the K&N was in use showed higher amounts of silica. Which isn't hard to believe if you think about it, more airflow = less filtration.
More choices...
