Old 01-22-2008, 08:04 PM   #1 (permalink)
WaxyChicken
Nomadic Chicken
WaxyChicken's Avatar
Alternative to big motor and big $$$?
Link:how to savlage cheap DC motors
There is a junkyard in my area where i can get these CHEAP. i mean DIRT CHEAP - say - $10 to $50 a pop depending on the actual original car.
instead of spending a fortune for a big motor, is there some way I can use several of the small motors for an EV construction?
I probably wouldn't be able to use one at each wheel because there isn't likely to be an easy computer balancing system to find, I'm thinking more of having 3 or 4 of them under the hood. The problem i see is one may grab the gear more than another causing one to do a brunt of the work.
Any ideas?
I'd like to hook them up to an Anderson CVT and i'm thinking of using a serpentine belt.
