Old 10-02-2008, 12:10 PM   #4 (permalink)
some_other_dave
Originally Posted by lyd View Post
Regarding the timing, I still don't understand what keeps the ECU from retarding the timing back to where the ECU wants it to be, even if you advance the base.
Probably because the ECU does not actually know when the ignition timing is. It simply advances or retards it from the current static timing.
-soD
