Old 10-04-2008, 12:31 AM   #8 (permalink)
jjackstone
Hi NoCo,
From all I've read, range is a real problem for most e-bike conversions. Just not enough room for the needed batteries. I've thought that adding a small aero trailer to carry either additional or even all the batteries would be a good idea. Using an industrial Anderson connector to attach the battery pack to the bike would be an easy way to both transfer power and allow for a simple disconnect so the batteries could be rolled inside for charging. If only the trailer were used for the batteries, that would also leave room in the "engine bay" for an onboard charger to catch the occasional opportunity charge. Just a thought.
John J
