Old 10-04-2008, 04:32 PM   #12 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
90 day: 43.96 mpg (US)
Hello -
Dodge tried, but I think it was too finicky and soaked up gas like a paper towel :
Photos of Chrysler turbine engines and cars
The turbine itself. Chrysler wrote: "The present performance and economy of the Turbine are comparable to a conventional car with a standard V-8 engine. The engine will operate satisfactorily on diesel fuel, kerosene, unleaded gasoline, JP-4 (jet fuel), and mixtures thereof. And, even more interesting, it is possible to change from one of these fuels to another without any changes or adjustments to the engine."
The big complaint from the consumers was poor fuel economy at idle and lower speeds. Unfortunately, this wasn't something further refinement could alter very much, since high rpm is inherent in gas turbine operation. I suspect this was the main reason that the U.S. Government ended its support for Chrysler's turbine research--the Goverment's goal was to lower fuel consumption in vehicles, not increase it, never mind the fuel flexibility.
CarloSW2
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
What's your EPA MPG? Go
and find out!
