Old 10-07-2008, 12:18 AM   #609 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Got to do a little work on the car today.
I removed that lifting strap that got "built-in" when I wrestled the engine in. Unfortunately, it was easiest just to cut it out.
The Vacuum system for the power brakes wasn't working right. I tracked it down to the thin hose that runs to the vac gauge. I wired up the vac pump so that it runs when you press the brake.
After doing a test run, I think I can say this is a good system. Just getting started powers up the vacuum and I don't think I ever saw it drop below 10 on the guage while braking.
I rigged up the forklift throttle in place of the hand potentiometer, so the car runs with the original gas and brake pedals now.
I also re-installed the ammeter and a large 0-100V voltmeter on the dash.
The car is much more "car-like" now that the power brakes turn on and off automatically, and it runs with the gas pedal.
I also finally rigged up the main contactor to run off the keyswitch, so I can't try to drive it without unlocking the steering any more!!!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
