Old 10-07-2008, 08:23 PM   #5 (permalink)
cfg83
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
93Cobra#2771 -
Originally Posted by 93Cobra#2771 View Post
carlos - you did go for a wider tire. A 195/65/15 is 10 mm wider than the stock 185/65/15 and slightly taller as you found.
What have you found in your mileage comparisons so far?
I'm wondering if the decreased deflection/ heat generation will cancel out any loss from the slightly wider tire? 10mm is less than 1/2" from sidewall to sidewall.
Thanks for catching that! I will post that on the thread as a negative. I will calculate the added frontal area. I am thinking it will be in the range of :
2 (tires) * 0.39(10mm / 25.4 = inches) * 6 (to 8 inches of exposed tire)
There will also be a horizontal increase in exposed tire area because the tire is slightly taller.
My main conclusion is based on the GPS/odometer correction. In my fuel logs I document a +2% distance correction from what my odometer is reading. I would suggest that whatever tire you get, you do a GPS before/after comparison. That will give you conclusive evidence as to what the gain is,
Caveat: I didn't think to do a GPS before test, so there is the possibility that my odometer was already -2% before the new tires.
CarloSW2
American Solar Energy Society
