I'm going to install mine with a speed pulse generator in a two-piece speedometer cable. I'm also using a vacuum servo and the relays from an A-R-A cruise that was made specifically for my car. That setup will allow me to mount the servo under the dash to work directly on an arm bolted to the top of the accelerator pedal. The only part mounted under the hood will be the two relays and their bracket. I need all the room I can free up to mount the tank for my Waag-Injection kit.
