Interesting. This does make sense, because I never experienced a lockup/reset before hardwiring my 'guino. Prior to that I was running off the 5v from my carPC which was far more consistent than battery power it seems. (But then again, my 5v stand by would only stay on for 2 hrs after shutting off the car, so I may not have been running long enough between resets to see the issue.)
Is there a way to burn a new bootloader with either the iDuino's USB interface or the Freeduino v1.0's serial interface?
