Old 10-09-2008, 05:46 PM   #10 (permalink)
Cd
Ultimate Fail
Cd's Avatar
[QUOTE=lunarhighway;66147]
in addition the airflow will in part force the doors close at speed
QUOTE]
Brilliant !
So true.
( Also, you plan to have the front lip curve inward into the wheel well ... right ? )
I am curious to see how you get around the problem of having the tires rub against the skirt when you turn the wheel.
I think Basjoos' idea of the conveyer belt wheels is brilliant, but I would be worried that the rubbing would eventually wear into the tires.
I know it won't, but it would if I built it !
