Lowering
The car rides much better and handles better with the Goldline lowering springs. The stock HHR would get blown around badly in cross wind or at higher speeds (60 and up). Now it is much better.
I also went with taller tires at the same time and not sure how much it has helped. I was so amazed at how much better it rode that I put the stock wheels and tires back on to see if it handled and cornered better because of the lowering or the tires. I think most of the improvement in ride is due to lowering. The stock HHR sits up too high with too soft of springs so I do not know if you would get the same improvments from your vehicle.
The tires should have a 10% speedometer error but I have not been able to verify that with my GPS. Seems to be closer to 5%? and that does not make any sense. According to several tire web sites and it says a 10% error.
According to my DIC the mileage is about the same but if there is an actual 10% error then in reality I have a 10% improvement?
Bottom line is I like the lowering and tires but the improvements is hard to say exactly how much. Curly
