Old 10-10-2008, 09:20 AM   #624 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
1st and 5th are completely useless gears in this car.
1st gear spins up really fast and isn't needed, because you can pull away from a stop in either 2nd or third.
5th just doesn't have any power with the gear, weight, and voltage of this system.
An EV can be built with or without a clutch.
You even CAN build one with an automatic transmission if you really wanted.
Usually the flywheel would not be shaved down, but rather buy or build a custom version of what a shaved flywheel would be like.
Machining something like that is beyond my skills. Buying or having one made would have been a budget buster.
This car drives like a golf cart in 3rd gear. You can pull away from a stop and go up to a little over 35 mph without shifting, using a clutch, or have anything weird happen when you come to a stop.
Just to compare, here is a video response to my YouTube video from another EVer:
Looks like his shifts a lot nicer. He's also using Optima Yellow Tops, which I know you can pull a LOT of amps from!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
