Old 10-10-2008, 04:05 PM   #2 (permalink)
Red
Red's Avatar
Send a message via MSN to Red Send a message via Yahoo to Red
You will freak out the ECU removing the alt. The voltage regulator is built into the ECU, so no alt, and the ECU thinks its dying so it pumps in voltage to the stator trying to make it generated juice.
Once removed though, you could just run a shorter serp belt
