Now Hydrogen is the basis for Helium, however, there is no way that I believe, that an HHO generator can replicate Fusion.
The intense pressure, gravity, centrifugal force and heat necessary, ala the Sun, is not possible in a $300 HHO generator.
Wanted to chime in with that gem ...
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
