Old 10-11-2008, 07:09 PM   #8 (permalink)
thefirebuilds
Puddles - '95 Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Miata Club Racing
Scooter - '05 Metropolitan
Monstro II - '99 Ram 1500
Kassia - '01 Miata LS
Precious - '97 3500 Silverado Dually
Originally Posted by trebuchet03 View Post
If it leaks, it's poisonous gas leaking in the cabin versus engine coolant
That, and it's a whole lot easier to route a relatively clean liquid than a much hotter gas
both good answers, I will also add.
-heat is exchanged easier, and more efficiently in a fluid
-antifreeze has an anti corrosive that should ideally keep the system working properly longer
-exhaust is wizzing out of your car as fast as possible, back pressure makes your car perform less goodish, where as the radiator fluid is restricted/slowed down by the therm to make the engine coolant exchange work better, and it doesn't _really_ effect engine performance.
