Old 10-11-2008, 06:42 PM   #19 (permalink)
roflwaffle
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Originally Posted by MechEngVT View Post
Since I can't locate a BSFC chart for the 1.6 TD in an amount of time I'm willing to devote to the search I can't see whether there are plausible scenarios to indicate which would be more fuel efficient in a given application. Generally engines of this size in a compact vehicle application cannot be forced to operate at a high enough load to achieve the exact operating point required to deliver peak BSFC in a cruise scenario. Put the engine in a full size truck however and you just might hit that point.
VW has enough in the way of gearing and wheel sizes that either can be geared to be at peak BTE at a cruise. Also, the VNT and change to DI allow for a relatively broad, in terms of 300-200g/kWh BSFC map so even w/o the change in gearing a 1.9 TDI would probably be as efficient as a 1.6 TD. That said, gearing options definitely vary by engine type so having a nice range of gearing options in terms of efficiency doesn't always hold true.
