Old 10-13-2008, 08:03 AM   #218 (permalink)
Funny
Funny's Avatar
Rolling Lemon - '02 Corolla S
90 day: 40.94 mpg (US)
Originally Posted by Coyote X View Post
I have two choices. Either just swap the head to a stock one and get the compression back down to 9.5:1 or try cutting singh grooves in the shaved head. If I cut the grooves I will try and increase the volume of the chamber to get the compression back to stock.
I don't think the grooves would actually help anything and would probably end up with the same result either way I do it. But if you had to do one or the other what one would you pick?
If you have two heads available to you, just experiment with the head you already shaved, throw some singh groves in it and see what happens, then if it still has the knock problem, switch back to a stock head and work from there.No harm, no foul.
American by right
Ecomodder by choice
Hypermiler by necessity
