Here's a suggestion for you. Take both heads and CC the combustion chambers. Take the milled head and start to slightly open up the chambers with a die grinder until enough metal has been removed to CC it to near original. Did you try to retard the timing a degree or two? I don't know if there are any head gasket options for a thicker gasket. Good Luck.
38 time NHRA/IHRA drag race champ
05 SRT4 / 12.17@117 mph on DOTs / 33.0 mpg
84 Horizon / 1760 lbs / 24 mpg
95 Neon / 46 mpg
2011 Prius / 62.1 without trying!
