Old 10-13-2008, 01:37 PM   #20 (permalink)
Blue Bomber Man
GreenMile - '00 Protege ES
90 day: 34.45 mpg (US)
It all depends on your budget really. A 10 kwh pack is around 10 grand for lithium ion batteries, but would only weigh around 140 pounds. The same pack using deep cycle batteries from something like a forklift or golfcart would weigh maybe 550-600 pounds but would cost quite less.
I would suspect a car that weighed around 2000-2200 pounds, with a more typical Cd of around .28-.32 and with low RR tires the range on a 10kw pack would be perhaps 35 city, only 25 high way miles.
It is worth the effort to drive the tires directly without a transmission because you lose some serious energy there.
If you are using an existing car, due everything possible to reduce weight, improve aero etc. Look up car designs that have low Cd and see if you can emulate that exterior.
Steal ideas where ever you can. Look up the Aptera, Probe V, LoReMo.
LoReMo has an interesting idea I plan to put in my car: no side doors, it uses a front hood/windshield door that lifts up. It saves a lot of weight because you can design the side of the car to be much stronger with less weight.
Good luck!
http://benw385.vox.com/
'Blog' on the open source electric motorcycle project.
Please come visit and comment!
