Old 11-27-2007, 12:08 PM   #317 (permalink)
MetroMPG
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
04-08-2007, 08:47 Pm
Fun with ammeters - making a load tester
Played a little this evening with the ammeter. Tried my hand at setting up a heavy-duty battery load tester.
One of the "professors" of the EVDL says you should be able to put a 75A load on a 6V battery and have it go for at least an hour before the batt drops below 5.25V (under load).
Hmm... Where to get a 75A load...
Some guys said: just dead short a very long piece of wire, like an extension cord. Someone else said: dead short a coat hanger, it's about the right resistance for its length.
So I dead shorted a coat hanger between jumper cables . Call me Sparky.
Just over 100A of current flowed at first, then as the hanger heated up, its resistance increased - and current dropped all the way down to 40A, where it seemed to stabilize (and the coat hanger gave off a toasty warm glow).
Repeat with the coat hanger submerged in a big pot of water, and current stabilized around 90A, with the test battery humming along steadily at 5.3V. I only let it do this for about 10 minutes.
So I'm thinking I'd have to make up some kind of test rig, and run each battery through it.
OR ... I was thinking maybe it would be easier to charge up the pack in the car, jack up the drive wheels, and spin the works in 5th gear - that's got to get be close to 75A. Then I could test & monitor a whole bunch of batteries at once.
