Old 01-24-2008, 12:19 AM   #4 (permalink)
malibuguy
MPG...what?
Malibu1 - '79 Malibu Classic
Malibu4 - '79 Malibu Classic
Terkle - '97 Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '010 Yaris base
90 day: 46.84 mpg (US)
Zoey - '95 Protege LX
90 day: 31.19 mpg (US)
Send a message via AIM to malibuguy
How do you figure?
Paper filters go 50,000m easy, in good driving environments even more. $35/$7=5; 5 x 50,000m = 250,000miles before k&n "saves" you money, if not longer. Don't forget the cost of the cleaning and reoiling kits! Oh, and the MAF cleaners you need to buy and use after the k&n gooks it up!
the car would have to use a MAF first to gunk it up, & second, most of those issues are from people over oiling the filters, i've never had an oily intake from a K&N filter
plus i have a recharge kit, since 5 other cars at my house use K&Ns, so 10bucks for a recharge kit every couple years is basically unnoticeable anyways
ram-air picks up alot of dust & dirt fast, paper filters load up & start dropping flow almost immediatly, which in turn cuts down on power & fuel mileage, since the engine must work harder now to draw in air & also potentially sucking dirt thru the filter due to higher pressure(vacuum) difference on the filter
then if it does increase MPGs in her car, which i suspect it will, since its such an undersized filter for the engine, but i've now almost doubled useful flow, it'll pay itself back pretty soon
alot of the time, K&N stock replacement filters don't improve upon flow, cuz sometimes, the stock paper element is quite large & has plenty of flow capacity for the stock/given engine, but when the filter is quite small for given engine, aka like a Cavalier, the additional flow from the K&N is actully usefull, & don't forget about the rest of the intake design, some cars have horrific intakes, i remember a friends '92 Escort LX had an opening around 1.25" in diameter!!! right at the beginning of the intake...removed that piece along with the resonator in the fenderwell, improved acceleration drastically & MPG from now having a almost 3" opening for the airbox
ok, enough typing for now
-Greg...the exhaust freak.
www.mandrelbend.com <-- I work there!
