Old 10-14-2008, 05:42 PM   #102 (permalink)
trebuchet03
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Duff, technically - the steels we use today do decay as they are metastable (not necessarily 100% metastable, as the internal crystal structure will vary). They can also rust, but if not exposed to oxygen, it will decay (over a long long long time) into a different form of steel. The transformation is accelerated by heat (maybe other factors, but heat is the big one). This is how bridges in CA collapse when a tanker catches on fire underneath them and etc. Due to the very long time it takes for steel to transform (into a weaker, stable crystal structure), you have no need to worry about all the buildings with steel structures or reinforcements - unless there's a big fire (then, hopefully the structure is redundant) :/
But, that said, the results of metastable steel turning into a stable form of steel is hardly a naturally occurring product. Even moreso would be Aluminum, aluminum is a highly refined metal that won't turn back into bauxite (well, maybe it could - but the time would be immense).
Some Leisure reading:
Martensite
Challenge me, or correct me, but don't ask me to die quietly.
