Old 10-14-2008, 08:57 PM   #10 (permalink)
Blister
Originally Posted by TestDrive View Post
You can probably snug the bed up yourself. Haven't worked on any newer pickups, was pretty straight forward on older models. Maybe Ford has had a better idea (special tool required) in the mean time. If you've got doubt's, ask for free advice at a body shop.
300 miles per mo or 3,600 miles per year.
10 mpg means 360 gallons @ $4 per = $1,440 per year in fuel
12 mpg means 300 gallons @ $4 per = $1,200 per year in fuel
15 mpg means 240 gallons @ $4 per = $960 per year in fuel
20 mpg means 180 gallons @ $4 per = $720 per year in fuel
Definitely best to concentrate on low hanging (least expensive) fruit
I agree with red, you want to find out exactly what's keeping the check engine light on. Various auto parts will scan the codes and turn the light off for you for free. Just be aware the codes don't tell you which part is broken, they only tell you which readings are out of spec. The codes are just a starting point to help decide what to test first.
If you can live without 4 wheel drive, I'd pull the front differential and front drive axles if possible (was doable on older Fords, should still be unless something has drastically changed). Once that's done, the combined 5,000 lb tractor and trailer really isn't all that much so put taller gears in the rear if you can get away with it. What's the current gear ratio anyway?
If you must have 4 wheel drive, badly mismatched front and rear gear ratios are not a good idea - lots of excess wear and tear!
I don't know the current gear ratio. I'm not sure how I would find that out either. I can say this though. I can do without 4WD AND air conditioning. The only problem with no air is the windows will be rolled down- it's hot here. I'm not sure if the drag from open windows will negate the savings from getting rid of the A/C or not.
Pulling axles and stuff is pretty new territory for me but our mechanic charges us very reasonable rates.
The engine light: No sooner had I posted the post stating it was a non-issue, my wife returned from town and was mentioning something about an idling problem. She said acceleration was "ify" and that it was having a noticeable idling abnormality. It didn't do this with me but then again, I didn't drive it far. We'll see how it does with a mechanics checkup in a week or two. The truck is new to us, only a week old on this end.
