Old 10-14-2008, 09:03 PM   #12 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
If you put a serious gear in it (like a 3.08) it slows the torque converter down and reduces the amount of fluid pumped to the cooler. Heat buildup causes spectacular failures, scattering parts down the road. It is a common problem with diesels where the engine is capable of high torque/low RPM operation for hours on end. Heat buildup cooks car-based automatics like the one in a F-150. Check out Ford diesel sites like thedieselstop.com and read the tales of woe among automatic guys who tow a lot.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
