Old 10-16-2008, 01:44 PM   #46 (permalink)
wyatt
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
Originally Posted by Tango Charlie View Post
...yet another way to do it would be to use pink or blue styrofoam from your local home improvement store. Cut, carve, and sand it to shape, then paint it with some latex paint. THEN fiberglass over that. The latex paint keeps the polyester resin from attacking the foam. Then remove the foam mechanically (grinding/sanding/ripping/tearing) or dissolve it with your favorite environmentally-unfriendly chemical.
Here is a web page that shows you a basic "how to" on using foam/fiberglass for construction. I think it looks so easy I may even try it!
