Originally Posted by brucepick
I'm getting mostly low 40's mpg and want more!
You might try resetting the ECU...
My D16Y5 was very sensitive to changes, so I reset it a few times a year - when the seasons changed, when I installed new spark plugs, when the gas stations switched from winter blend to summer blend, and so forth, and so on - and it always made an improvement!
I drove my HX with a stock motor for 7 years, and it got 44-52 mpg, for the most part. I got 38 mpg a couple of times, like when I drove it off the car lot (brand new) and when I burned in some brake pads. I got 62 mpg once - and 50-60 mpg several times, although it was NOT the norm.
45-ish mpg would be what I would expect - haven driven HXs for years...
