Old 10-17-2008, 09:10 AM   #9 (permalink)
metroschultz
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
They did it on purpose
misspoke
Originally Posted by FunkSkunk View Post
Nice Job Trik!! .... You'll be surprised how misleading those factory gas gauges are!!
To keep a small volume of fuel in the tank for the pump.
Usually around 2 gallons.
Think of your fuel pump as a small engine.
It needs lubrication and cooling.
The fuel in the tank provides these for it.
If you run your ICE without coolant or oil it would die rather quickly.
If you continuosly run your fuel pump beyond "E" it will die also.
No fuel means no lube or cooling for your pump.
I understand the desire to see how far you can go on one tank.
I just want you to be aware of the possibilities of draining every last drop of fuel from the vehicle.
YMMV,
Schultz
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
