Old 10-18-2008, 01:32 AM   #172 (permalink)
Concrete
Sequential
Concrete's Avatar
The Truck - '00 S10 Extended Cab
90 day: 22.47 mpg (US)
Frank,
yes that is stupid
the "facilities charge" should be pro rated per kWh
like I said before
I would be happy if we could just stop distorting the market
that is a rather regressive system that almost subsidizes non conservation
you just got notice?
is the rate set for sure or is just set to go for approval?
(around here you usually get a shot a contesting such moves before the are set in motion)
Concrete
Start where you are - Use what you have - Do what you can.
