Old 10-18-2008, 02:59 AM   #31 (permalink)
kimer6
Liqui Moly for diesels
Originally Posted by tasdrouille View Post
If the problem is just the injector nozzles you could give Liqui Moly Diesel Purge a shot. Lots of people run it straight at the fuel filter in TDIs to clean sooted injectors.
You can buy it from a TDI community trusted vendor.
Thank you...for 9 bucks I'll give it a try. Can't hurt to test it.....maybe I'll stumble onto another use! Like the time I was using Berryman B-12 Chemtool on motorbike carbs and got some on the wart I had on my finger for 30+ years. I scraped it and it was bleeding. When the B-12 hit it, I almost launched like the Space Shuttle it hurt so bad. Ha ha, wart removed forever!
