Old 10-18-2008, 06:16 PM   #6 (permalink)
bbjsw10
Addicted
bbjsw10's Avatar
bbjsw10 - '91 Metro Xfi
90 day: 51.06 mpg (US)
Originally Posted by Coyote X View Post
Making the sprocket mount should be pretty easy. Just find a non cushioned drive motorcycle rear wheel hub that has an axle shaft size big enough to stick the cv axle through and center and weld it solid. The sprockets are big enough to slide over the cv joint and bolt to the hub when they wear enough to need replaced.
The nice thing about this as well would be sprocket selection, tons of them on the market of different teeth count.
Good luck on your project. If you get it done for Geopalooza next year you should bring it by.
