Old 10-19-2008, 10:06 AM   #40 (permalink)
kimer6
Jetta injection pump
Originally Posted by Jetta90GL View Post
I'm not sure how similar a kubota pump is to a VW pump, but I modified my governor on my Jetta. It gave me full throttle control through the entire rpm range. There is a write up on it over at the VW GTD forums
Thanks for the info....now whose dumb idea was it to put a tractor engine in a car? I kind of knew the Kubota governor was not suited to road use. After looking at the cutaways you sent, I see that the VW pump has variable injection timing. I can't find a drawing for Kubota. But the governor/pump is part of the engine casting and there is almost no chance of replacing it with an automotive pump. Kubota timing is adjusted by shims. I don't think it has speed sensitive timing. Like Briggs&Stratton has fixed spark timing. OK for a lawnmower.....
