Old 10-21-2008, 03:10 AM   #13 (permalink)
TestDrive
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Pneumatic Impact Tool: selection, use and information
Originally Posted by Twerp View Post
Somebody once told me that it's PSI that makes the real difference with impacts. If that is the case, I was able to get some decent pressure. I just might not be able to sustain the harder blows for long. So with shorter bursts, it might work... maybe...
PSI, CFM, tool design and manufacturing tolerances are all very important.
Typically a 1/2 pneumatic impact will have 2 to 8 vanes or hammers.
In general more vanes means more more blows per minute and greater delivered foot/lbs torque for any given PSI.
Turning up the compressor's cut off pressure will help regardless of your particular pneumatic impact gun.
But no matter how much you may wish and no matter what you've been told, it's not going to turn a
$35 2 vane / 2 Hammer Central Pneumatic
into a
$290 7 vane / 7 hammer Ingersoll-Rand
The 7 vane gun connected by an adequate ID hose to an adequate volume tank pressured to 90 psi will deliver more foot/lbs of torque than a 2 vane gun using the same hose connected to the same tank pressured to 120 psi.
For purposes of exposition, here are the specs for the second gun with my comments in red.
  • 7-vane motor 3.5 times more vanes than 2; probably not much more than 2 times the torque
  • Torque range: 50-600 ft. lbs Better tools have greater range and finer control.
  • Max. torque: 625 ft. lbs. (fwd) Torque of each clockwise hammer blow.
  • 700 ft. lbs. (rev) Torque of each counter clockwise hammer blow.
    More umpf loosening than tightening! Not always true for cheaper tools.
  • Nut-busting torque: 1000 ft. lbs Maximum 6 seconds cumulative - see below.
  • Impact: 1250 BPM Blows per minute under load.
  • Free speed: 9500 RPM
  • Standard bolt capacity: 9/16' Shaft size not head size
  • Average air consumption: 5 CFM (24 CFM under load) Under load CFM is the important number.
  • 1/2'' anvil
  • Tool weight: 3.95 lbs. A lighter tool of equal torque will cost more.
From the main body of the advertisement - "Can loosen a nut tightened to 1000 ft. lbs. in 6 seconds" Six seconds is 1/10 of a minute. The gun delivers 1250 hammer blows per minute, so this is an estimation of the cumulative effect (static torque) of 125 hammer blows each delivered at 700 ft. lbs. of torque.
Let's talk about air hose for a moment. Though, the inlet of most any 1/2 pneumatic impact is going to be 1/4" NPT, it is very, very, very important to connect it to the compressor tank using at least 3/8" air line.
1/2" air line is better yet and is almost required if the hose is very long more than 25 feet.
When you hook a pneumatic tool up to the compressor tank and use it, air is depleted from the tank. When the pressure drops below a preset level (say 80 PSI - LESS THAN MOST ANY IMPACT GUNS RATED PSI ) the compressor kicks on and attempt to replenish the depleted reservoir. If the compressor and tank are adequate and you're just doing run of the mill work - you just continue on and the compressor eventually catches up. However if you're working on seriously stubborn nuts/bolts - looking for maximum torque, it's time to stop using the tool and wait until the compressor kicks back off. Then with a full reservoir tank at maximum PSI, you can try again.
The bigger the compressor tank the longer your tool will operate near it's maximum torque. Again you need adequate size hose running from the tank to the tool.
HOW TO SQUEEZE EVERY LAST BIT OF TORQUE FROM YOUR EXISTING PNEUMATIC TOOLS
  1. Be sure you compressor is turned up to it's maximum rated PSI, but not more than the maximum rated PSI of any reservoir tank. (SAFETY FIRST)
  2. Use you shortest, largest ID hose to connect the tool to the reservoir tank.
  3. Deplete enough air from the reservoir to force the compressor to cycle on and wait for the charge cycle to complete.
  4. Squirt 1/8 to 1/4 teaspoon of pneumatic tool oil directly in to the input port of your disconnected pneumatic impact tool and reconnect. This squirt of oil will briefly (1 second or less) boost the tools effective torque at it's next use. Oil will spray out the exhaust ports of the tool. If 1/4 teaspoon of spaying oil is going to be a problem, wrap the tool in a shop rag prior to use.
  5. Operate the tool in a 3-6 second attempt to loosen the stubborn fastener.
  6. If your reservoir tank is still with in a PSI or two of maximum, repeat steps 4 through 5. If your reservoir tank is too far below maximum PSI, repeat steps 3 through 5. If the fastener hasn't come loose after 20-30 repeats, sorry, you need better equipment.
If you need better equipment, replace sub-par hose first.
If you can borrow a better impact tool, do so.
If you have a tiny reservoir tank and you tool's rated CFM is high, try adding an auxiliary reservoir - even if the new auxiliary tank will require a slight lowering of maximum PSI. (See step 1 above).
If you have to buy a more powerful impact gun, keep your old one. Only use the newer, better tool on stubborn fasteners. Performance degrades - they only hold up so long.
Last edited by TestDrive; 10-21-2008 at 06:58 PM.. Reason: Added content; correct minor errors; revised for clarity
