Hi,
Will you be able to delete the driver's side outside mirror?
Also, would you get a better/larger view of the outside if the mirrors were rotated 180 degrees; so that the radius was on the lower inside corner? That way the straighter edge could be positioned close(r) to the window, and show more of the outside, and less of the inside.
