Old 10-22-2008, 11:50 AM   #11 (permalink)
bennelson
"Crush"
bennelson's Avatar
Electric Cycle - '81 KZ440
90 day: 334.6 mpg (US)
S10 - '95 S10
90 day: 30.48 mpg (US)
Electro-Metro - '96 "Electro-Metro"
90 day: 129.81 mpg (US)
The Wife's Car - Plug-in Prius - '04 Prius
90 day: 71.8 mpg (US)
Yesterday, I installed a kill switch in the truck.
Today, the CHECK ENGINE LIGHT no longer comes on, but I am having another problem instead!
I have no power when I put the gas pedal down farther than about half-way!
This gives me terrible acceleration, and I can barely make freeway speed. I can slowly accelerate if I am level or slightly downhill.
Uphill, things start slowing down because I can't push the gas pedal down far enough before it starts losing power!
Also, if I rev the engine up real high, when in neutral with the parking brake on, it sort of shutters and snorts.
Is this a "fuel-rich" problem? When I give it gas, it's getting too much gas, and I lose power?
When I installed the kill switch, I cut the wire to the fuel injectors, and added a momentary off relay in-line to it to turn off the engine.
I put a jumper back in so that that wire is connected directly again (no relay) and am still having the same problem.
Please don't tell me that that's a special wire that has very particular resistance that effects the injectors or something like that!!!!!
What could be wrong with the truck?!?!?!
Thanks in advance!
300mpg.org Learn how to BUILD YOUR OWN ELECTRIC CAR CHEAP
My YouTube Videos
