Old 10-23-2008, 04:29 PM   #27 (permalink)
TestDrive
WonderWagon - '94 Escort LX
Last 3: 51.52 mpg (US)
DaRedOne - '99 Escort ZX2 Hot
DaBluOne - '99 Escort SE
90 day: 48.97 mpg (US)
Originally Posted by 12voltsolar View Post
Hey TestDrive, not sure that it needed to be cleaned only, may have been, but as I say it already was replaced (past tense)...
How long since it was replaced?
Every time the air filter is inspected is an opportunity to introduce a spec of lint/dirt. It only takes a tiny spec of gunk on the small heated wire that is the guts of the MAF to cause inaccurate air flow reading for the ECU.
Also if you've installed a K&N or other "high performace" filter that requires periodic cleaning & oiling, even a slight over oiling will lead put a film on the guts of the MAF and cause inaccurate readings sent to the ECU.
