Old 10-25-2008, 12:46 AM   #31 (permalink)
jomelmaldonado
Puerto Rican Hypermiler
jomelmaldonado's Avatar
Suzuki Swift Gesta - '98 Swift Gesta
90 day: 46.14 mpg (US)
Well, I was planning on only using the RPM, but I found the VSS wire, taped it near the ECM. It was a little bit confusing because I could only find the Geo Metro diagram, and mine is a Suzuki Swift, it changed the color code for the wires, but it turned out OK. You can set your CCS-100 to read VSS with the DIP Switch settings. I will be posting the progress of this experiment on the week.
