update ... finally got a proper usdm VX intake manifold w/TB and swapped it in , i noticed the jdm 1.5L vtec-E IM looked very similar to the VX except the TB was about the size of a DX or EX Tb. Now to adapt or find a cx/vx air-tube to my EX/oem air filter box. home depot lookout! the VX tb is about 2" diameter so ill need to adapters like a 2-2.5 and a 2.5 to 3" or such. New cat welded in back in July so gettin close to stock. Also put on some new Kumho Solus 185/70/13 tires 70k so that helps along with an adjustable front Upper-A arm camber kit & new bushings for them A-arms.
what u don't know, CAN hurt you because if you don't know your rights, its like you don't have any at all. ID Theft Services & Resolution available... check out
http://www.prepaidlegal.com/hub/deantaber
