Old 10-27-2008, 10:04 PM   #55 (permalink)
hhometro
VEGGIE - '85 300d turbo diesel
SPANKY - '96 METRO
Send a message via AIM to hhometro
Originally Posted by Hacksaw View Post
On my 1995 Hatchback, the location you have circled houses my temperature gauge sending unit. There is a coolant passage behind your bolt/plug and should be sealed back up so it doesn't leak. I will try to take a picture or two of mine tomorrow, but I installed mine just inches away from that bolt, where the 3/8 line goes from the manifold to the hardline on the firewall leading to the brake booster. I know Johnny Mullet has questioned the safety factors and quality of vacuum from here, but mine works very well.
so did you just out the sending unit it and close it with the nut and tighten it
