You should be able to tow that if you have a gasoline car. You may have to put the batts and the motor in your car (on a separate trip) to lighten the load, but a car should be able to tug that in most cases.
When i worked at a factory site we pushed around forklifts that ran out of propane to move them out of the way.
Congratulations with your find.
I was contacted about 3 forklifts for sale at $400 each, but no way to get enough money for one. i hope you have better luck.
Edit:
hell, just build a tank with that motor. :P
