Old 10-29-2008, 04:08 PM   #40 (permalink)
Jim Allen
5.4L Econo Box
Jim Allen's Avatar
Plugger - '05 F-150HD 4x4 XL
Originally Posted by CapriRacer View Post
Jim,
Don't bother. The testing that will prove this is going to trash the tires under braking. The only other way would be to do skid pad testing of lateral G's - but that's going to trash the tires, too!
Not to mention that heat in the tread compound is going to affect the test results, so the only way to get a good test is to have many tires already mounted up and a guy standing by to do the changeover.
Bummer! Yeah, that makes sense. Well, anything that trashes my tires is a no-go fer sure. I'll fall back on my tire contacts and see if I can get some test info on the tires they trashed. That study that was linked to from Goodyear was interesting but it really didn't answer the question of if, or whether, braking performance degraded at the high end of the pressure range, above the 35 psi listed (which I took to be the max pressure rated for the tire). They were looking at the low end pressure... which, truth be told, is the scary end they should be looking at from the safety standpoint related to neglectful car owners.
I think it was you that talked about a "sweet spot." I'll bet there's one that offers the best of all worlds, performance, safety AND fuel economy, and I'll bet it different for every tire/car combination.
Jim Allen
The Frugal Four Wheeler and Farmer
My ultimate goal is not necessarily the highest mpg but to make my trucks more efficient configured as I need them.
Old Reliable '86 Ford F-250HD 4x4, 6.9L diesel
Red '00 Honda Accord Coupe, 3.0L V6, automatic
The Plugger '05 Ford F-150HD 4x4, Regular Cab, 8-ft bed, 8,200# GVW, 5.4L V8, automatic, 4.10:1 ratios, 285/70R-17D tires
