Grab a meter and check the voltage across the battery with the engine running. It should be more than 13 volts. With the engine off, the voltage on a good battery should be more than 11 volts. If the battery won't take a charge, it won't matter if you have a new alternator or not.
moorecomp
Mancelona, MI
