Old 11-01-2008, 05:52 PM   #14 (permalink)
2000mc
herp derp Apprentice
saturn - '99 sc1
90 day: 35.67 mpg (US)
Originally Posted by Twerp View Post
I borrowed an IR 600lb impact from a guy that I work with and that didn't do it.
if that didnt do it, i'd be more concerned about breaking off the head, and leaving the rest of the bolt in the crank. guess i'm not quite sure if the car has been disabled until the pulley is replaced, but if not, stop. if it has been, putting money into impact vs. going to a mechanic, may not work out finincially if you have to take it in to get the bolt drilled out.
i have a IR 2135qti, compared to the older IR composite guns (600lb) its lighter and faster, but it probly wouldnt be more helpful in your case. if a older one cant budge it, 95% of the time a newer one wont, or it will take the head off. or if you must anyway, the new 2135timax has 780lbs in rev. and 1100 nut bustin
