Old 11-06-2008, 02:03 AM   #8 (permalink)
RH77
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
Originally Posted by Johnny Mullet View Post
If the exhaust rattles, the cat melted down and is throwing the code since it's not cleaning the exhaust like it's designed to. I removed my cat for performance reasons and simply tied my 02 sensor (downstream) to the frame and it keeps the light out.
The major rattle/buzz is coming from an inner-tube style A-pipe that busted loose years ago (very common Honda flaw). I pulled the heat shields as well -- all they did was rattle.
Something else further back is rattling -- likely the muffler. The 3rd random clanking occurs at low RPM idle -- the source can't be ID'd. It's a loud metal-to-metal clank/squeak.
I used a data logger to check the pre- and post-cat O2 sensors and compared the output to an expected voltage chart (about a year ago). It all was well, yet the rattles haven't changed.
What's the average service life on the converters? The car won't pass inspection without one (which is coming up -- plus I wouldn't feel comfortable with the emissions factor)...
-Rick
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
