Old 11-06-2008, 04:38 PM   #109 (permalink)
wyatt
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
Hey basjoos, I just came by 3 sheets of coroplast (ie. campaign signs). Full 4' by 8' sheets, and I am thinking the first thing I will do is the smooth under body. When you did yours, how did you work that with the exhaust? Is coroplast rugged enough to take that kind of heat? Also, any special considerations around the wheel/suspension area? I think the under body should take about two sheets, with enough left over for some frontal blocking. I guess the third sheet can be used for something else... perhaps making wheel deflectors/boat tails and a set of rear wheel skirts. Any thoughts?
