Old 11-07-2008, 04:35 PM   #261 (permalink)
trebuchet03
MechE
The Miata - '01 Mazda MX-5 Miata
Originally Posted by Magister View Post
For OBD logging to a laptop, you'll have to enable the serial port and in the get_pid() function you'll have to do a serialWrite() with the info you want to export.
Excellent, just as simple as I was hoping
The transistor is used to drive the brightness as some LCD LED can take 100mA and the pins only output 20mA so if you plug the pin directly on the LCD, you will burn the pin output.
Thanks, I'm sure I have a suitable transistor somewhere
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
