Old 11-09-2008, 09:50 AM   #18 (permalink)
MechEngVT
Mechanical Engineer
The Truck - '02 Ram 1500 SLT Sport
90 day: 17.57 mpg (US)
The Van 2 - '06 Odyssey EX
90 day: 18.48 mpg (US)
road hazard meets rotating tire,tire launches road hazard into coolant line,line breaches,driver on side of road with thumb out?
Your best bet is to use a metal tube mounted to the vehicle's chassis. I've actually been in powertrain design on a mid-engine vehicle with a front-mounted radiator that was a 4x4 for off-highway only use (hence my experience with difficult coolant purging). It used a steel tube weldment under the floor of the vehicle that was still up between the frame rails but the finned aluminum extrusion may work as well.
When I was in college I participated in FormulaSAE and weight reduction was a key goal. Just between the mid-engine and the sidepod radiator we found a couple pounds of weight savings by using rubber hoses only for bends and flex couplers, and using steel thin-wall tube for straight runs. The metal tube is lighter AND more durable.
