Old 11-09-2008, 02:00 PM   #23 (permalink)
instarx
EcoModding Dilatant
Volvo - '00 V70 XC AWD SE
90 day: 27.7 mpg (US)
Originally Posted by Duffman View Post
I think more so than in a gas engine there is an optimum intake air temperature in a diesel. Cold air is more dense and therefore has more O2 which is definately good for FE but a diesel also requires heat to run so a charge that is to cold may not run well either.
Diesel's do not need heat to run - they need compression. The compression provides the heat. In every circumstance in diesel engines, the colder the intake air the better the efficiency.
Well, re-considering - if it is very cold the diesel needs some additional heat from the glow plugs for a few seconds, but that's a special case. It never needs warm air.
